Position wrong
Lassar
SatelliteGuys Guru
149
Illinois
My dad's C-band 4dtv system is messed up.
It just happened all of sudden. One day it was working fine. Next day it is messed up.
I tried master reset. Got it working for a little while.
The position is way off.
It seems that the dish some how moves way too much east.
It moves east and west, but will not hold the position count.
What is causing the problem ?
Bad reed switch located under the motor gear cover on the actuator arm. It may have two very thin gauge wires on it leading to a terminal block. Those switches are cheap.
I would stand out near the dish while someone attempts to move and watch for anything unusual during movement. Binding or noises?
Any chance the actuator arm slipped loose in the clamp? I've seen the additional weight of snow and ice cause that.
Any lost motion in the pivots or mounts if the dish is gently moved slightly?
I had a problem like that.
I was using a very old jack that was frozen until I broke it loose and oiled it up. It worked sorta but had problems like you describe. I had a brand new Von Weise that I was not wanting to use because I live in a very rainy area and hope to move soon.
Anyway I finally just gave up on the old jack because I was always having to adjust the location once I got to a satellite. I put on the new Von Weise and never have to touch it anymore.
It really made a huge difference
NASA Feeds on AMC3
LNB NEEDED
