As most of you probably have noticed Sd does not typically look good on Voom. As some may have tried, they discovered SD looks actually pretty decent when hooked up via composite or S-video. If you want to have a better understanding why that it can be a good thing to hook up SD via these two "lower" cable standards, read this at the Avs Forums: http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=320181
When you read it, ignore the fact that the author originally wrote it to help Plasma owners adjust their SD settings, and specifically focus on the part: 5. HOOKING UP YOUR DISPLAY FOR BEST NTSC QUALITY. Hope it helps some of you.
