I purchased DirevTV in July 2004. The picture quality is not quite why I feel it should be. Let me explain what I have, what I have done, and what I have been told the problem is and see what others think:
Equipment:
Sony KV36HS420 36" HD Ready TV
Samsung Receiver with Tivo
Hughes Direct TV Receiver
Sony DVD Player
Sharp DVD-Burner
What I have done:
I ordered DTV in June 2004, and had it installed in July. When first installed, it I had a 27" Sony tv that was old and needed to be upgraded. I then purchased high quality RG6 coax cable and ran all new wire throughout the inside of my home and terminated it into wall plates. Then I plugged the other end into a multi switch (3x8). When I bought the new tv, I ran the LNB A and B lines from the outside of my home and ran them into the A and B side of my new switch. Installed the TV and had a fairly good picture. It's grainy and pixalted at times. Talked to the salesperson, and he told me that I may need to power the 3x8 switch, that the cable run might be too far to be powered by the receivers. So, I bought a power supply. It improved the picture quality when I powered the switch.
However, it's still grainy and pixelated, especially the logos for the channel I am watching and the score boards for sports in the corners. Again talked to Salesman. He told me one of two things could be the problem:
1) Poorly terminated coax cables. Specifically the end is not touching an adequate amount of braided shielding and allowing interference in the line.
2) Poor cable connection from the satellite to the switch. This could either by the cable first installed by DTV, or it could be the cable that I added onto it to extend it, or Both.
Since my roof has a 38' peak and sharp pitch, I don't really want to climb up on the roof unless I have to. At the same time, my entertainment center weighs a ton, and I don't really want to disconnect it to get to the wall plate. However I will do what I have to do to fix the problem.
Any ideas on the Problem ??
Since the DVD player plays crystal clear on the TV I can assume that the TV is good, and I feel I should be able to get a picture reception similar to that of the dvd player when watching DTV, agree ??
Equipment:
Sony DVD Player
Sharp DVD-Burner
What I have done:
