This is a continuation of the topic - modded Russian LNB. Answer on page 51.But in the old topic my answers were about the circular C bahd irradiator. How to do it yourself.And to watch linear channels of the C range, you need to remove the cross plate from the irradiator. And there will be normal reception of satellites in C bahd - linear. Tested in Europe on satellites 75e, 55.5W with excellent reception. And some photos. I am sure you have craftsmen to experiment with a new irradiator for C band. Thank you.
I checked on my 1.1m antenna, the signal is weak, I need an antenna for my area 1.8-2.0 m.
Polypropylene C band irradiator for prime focus (long-focus) antennas with an opening angle of 100 degrees.Excellent reception.
For classic direct focus antennas with an opening angle of 125-135 degrees, it is not suitable. (Not effective)
In the photo, the antenna is 2.6 m. Very heavy, pressed from one sheet, 3 mm thick. This is a long-focus direct focus with an opening angle of 100 degrees.
modded russian LNB
have anyone here have been able to use one of these modded Russian LNB, are they really worth it?, I can bearly speak english so I know nothing about russian, can someone explain more about them? Thanks.
www.satelliteguys.us
