1-3/4 of an inch in diameter pole would be perfect for the WS9036 dish!!! :up
Just make sure you are not too high off of the ground.
I am about to install a 36inch WS International dish in the ground. Would anyone know if an 1 1/4inch outside diameter pole would be strong enough?
I am going to use the 1 1/4 inch pipe. And keep a close eyes on it and make sure its not to high off the ground. Thanks for the reply and everyone else who has replyed.I have 2 36 inch motorized dishes on 1 1/4 inch 6 foot pipe and have not had any problems. They both have gone through some really bad wind storms and didn't phaze them at all.
Thanks for the information. I will keep that in mind.8' Schedule 40 2 1/2" Pipe will cost you $20...If you ever want a bigger dish you don't need a new pole. Here in the Midwest I go 2 1/2' down minimum. Most guy's around here set a Dish 500 1' down with cheap pipe. If they can't dig the ground 1' they go less & use a cement cap. I buy the good pipe. If you are in a cold area Freeze & thaw will move your pole if you do not go deep enough. We need to go below the frost line here in the Midwest.
