I have a 6 foot 1 5/8 inch o.d. ground pole that is 3 feet above and below ground. It is set in a foot and a half wide hole, so there is a lot of concrete in there. Very stable and plum. Currently using a Dish Net Turbo dish.
Considering going to Shaw Direct with the 75e dish. That uses a 2 inch o.d. pole. How stable is the SKY1101 1 5/8 to 2 inch adapter? What if two holes were drilled through both sides of the ground pole, and two more holes on the other side of the adapter, and clamping the adapter this way?
This would be a temporary solution until it gets warm enough in Ohio to install the 2inch o.d. ground pole.
