Polarotor Connections
  • Thank you for a great 2025 and we are so looking forward to 2026! PLEASE CLICK HERE to find out about some of our plans for 2026 including our BRAND NEW NAME we will be moving to in 2026! Exciting times are ahead! Happy New Year from your friends here at SatelliteGuys.US!
adrian
55
How do one connect a C band LNBF with polarotor to receive linear and circular transmissions to present day receivers.Or ,can present day receivers be modified to take the three polarotor wires.
I believe the modern Pansat 2800 and 3500 FTA receivers can run your polarotor.
Check the docs to confirm.
As for Circular C-band and Linear C-band, I don't know how to do that on the one LNB
I've seen a plastic slab you insert into the throat of the horn to turn your linear into a circular, but no way to do that on the fly.
If there is, I'd like to know too. :)
Polarotor
Thanks Anole.Writing from Africa i was hoping for an easy way out as we have several satellites which have circular polarity.Then there are four satellites which have linear H/V polarity and when i remove the Teflon plate ,there is a dramatic increase in signal strength on these satellites.Do you have C band satellites with circular polarity?
For the record i have ascertained that a polarotor LNB can be connected to the Pansat 2700 and 3500SD.Any member wishes to come in on this subject?
KCSG On Galaxy 25 C Band
Help How to test the motorla DSR-920
