I,m setting up my DG-380 motor with a fortec 31" dish useing a Fortec star reciever i just purchased from Sadoun . After several days of fiddling , i don't get any signal . In my wiring setup is basic ,, lnb to motor then to reciever ( no switches ) i have the connection on the lnb ( cuad polar ) to only one L output and reciever is setup for Galaxy 25 Ku - 97 W, lnb type 10750( closest to sout for me ) , positioner i tried both Diseq 1.2 ans USUALS . Now for the question , The elevation and declanation angle table that came with the system coverts my elevation angle to 48 deg. my actual latitude is 42, i was reading and every where i get info it says to set the elevation on the motor to your latitude ( 42 ) and the dish angle should be 28.5 . My actual longitude is -79,408 and latitude is 42.425 . what setting is correct , please help ,,,,, frustrated
and yes i am pointed at true south , i used the sun when it was in highest point in the sky method
