After I finished several renovations to my townhouse, including wiring almost every room with OTA, satellite, cable, network & phone ports, She Who Must Be Obeyed decided she wanted to move to a single family detached. After carefully explaining how we spent top dollar on new windows, new kitchen, etc, and how it doesn't really make any sense to move, I succeeded in convincing her that she was gonna win this one.
So now I must start all over with the wiring in a new place we are seriously considering buying. There are no open ceilings I can access, and no basement. I can get at the upper level from the attic. I figure I'll be cutting drywall to fish down to the lower level, or running wires outside the house (I HATE that, appearance wise). In the townhouse, I used plenum rated cat 5e throughout. Some cables, and some coax & phone lines, went thru ducting. I want to avoid that in the new place, but may be forced to go thru ducting.
I understand that if I go thru ducting, I am supposed to use plenum rated, but in wall I am not. Posts indicate it will be quite difficult to put connectors on plenum coax. I've always used crimp inside the house and the installer always used compression outside the house. Other posts discuss copper vs copper clad steel without seeming to show a great advantage either way. Quad or triple shielding is mentioned as the better way to go.
So how should I go about doing this the "right" way in the "new" 1977 built house? If I can, I will run 3 or 4 coax to each drop and try to centralize them all at some point, probably in the attic (2 for ViP622, 2 for 721, 1 for 508, extra to run "stereo agile" coax output to another room TBD, plus OTA). Existing cableco coax will be left in place separately. Two network and one phone will be run also. I'd like to put the network patch panel next to the cable distro point, but the attic may get too hot for a DSL modem and router.
Since I'm running the coax anyway, is it better to run separate OTA coax and avoid diplexers? I've done it both ways in the townhouse.
Are compression fittings really needed inside the home? Crimp "more than good enough?"
If I avoid the ductwork approach, is there any reason to pay double or triple to get plenum rated cables (coax, cat 6, phone)?
I'm leaning toward getting a composite cable such as this for ease of installation. It has 2 RG-6 quad shielded copper clad steel coax and 2 cat-5e (not cat 6). I'd also use this double thorax cable- 2 RG-6 quad shielded copper clad steel. Both cables claim to be swept to 3 GHz and neither are plenum rated.
Is there a channel way specifically designed for running cables outside the home for improved appearance over bare cables?
I'm having no luck in finding twist counts on phone cables- anyone recommend a high quality phone cable source?
Any other considerations or suggestions on "doing it right?"
Thank you all for any assistance you may render.
