I got two Dish Pro with dual LNB(119,110+148), plus two DP21 switches. Do I need somthing else, becouse reciver doesn't recognise second switch?
Thank you.
You really don't need another Dish500 for 148, but it will work. How many receivers do you have? If only the one, with the set-up you have you only need one DP21 switch. Are you getting the channels you desire from 148?
More details are needed.
Best solution is to get a DP-34 switch which allow three satellite inputs. Get rid of your DP21 switches they will not work on the 721. Then run your check switch and voila you will be connected.
