I am putting in my own 1000.2, spent too many hours trying to align it today...and reading on how to. I have a new 211k hooked up and working...however I am getting 110 and 119 on the wrong lnbs which I read is common when aligning. However, I have tried everything I could find and I cannot get this thing to see 119 on the center lnb. The mount is level and plumb. The only place I can get signal (110 and 119) is when the elevation is 10 degrees too high and we seem to be too far south. This Dish was setup and working at my rental house, I moved it and did not adjust the EL and SKew until after I found it would not pick up. Apparently it can see 119 on the 110 lnb....and in the signal screen it says 129 is seeing 110. Oh yeah, I even tried another LNB set I bought for a second install, just in case the center was bad...but same result.
On the check switch I get:
1 2 3
110 X 119
ok ok
Any idea what I am doing wrong?
I covered the 110 and 129 (left and right) and tried to tune 119 on the center (rx on port 1) but absolutely cannot find it anywhere, and tried EL from 29 through about 44. about 40 is where 110 and 119 come in but on wrong lnbs.
One question is...from other stuff I read it didnt say, but if I have this comdition, people said move it right (west) 9 degrees....do I have to change EL or SK to get 119 if I do that?
I am really confused. I am not trying to play dish man, but I have aligned several 500's and never had any trouble.
I work with equipment other folks have trouble with all the time and I post on forums like this to help the out...I was just hoping someone could give me some advice.
Thank you.
1 2 3
110 X 119
ok ok
Thank you.
