Have microHD connected to HDD (DVR) via usb cable, have setup timer for one time programming with no problems, everything worked as it should, and was able to review the recorded program.
HDD is still connected to the microHD, and whenever the microHD is powered up the HDD also comes on, which I beleive that it is normal.
Now, here is my question. Do I need to turn the timeshift Off, on the DVR setup window after the recorded program ends, does it matter one way or another.
I just noticed that as I was wieving another program and checked it's status via the "Info" button, that it looked as if that program was being recorded into the HDD without me doing or activating anything, and could not stop it or cansel the function. Went to another channel and the same thing happened, the timer bar in the "Info" window started to count up.
Right now I have all the timers Off, on the timer setting window, and the timeshift On, on the DVR setup window.
Any recommendation or advice is greatly appreciated as to the normal procedure and status that the microHD should be after a recorded program ends.
Thank You.
Thank You.
