After helping others do this, I finally made myself a Phase III Dish set-up with a SL3 LNB to carry around in my camper:
The newer Phase III dishes use the same 2" OD mount that the slimline dishes do, so I had to find an older Phase III dish with the smaller 1 5/8" OD mount to fit my existing RV dish mount.
I ground the "nub" off the SL3 LNB so I didn't have to notch the dish arm.
Set-up at the campsite was longer than normal, I got a signal strength of:
Sat 99: high 60s to high 70s
Sat 101: high 80s to high 90s
Sat 103: high 50s to high 60s
When I tested the set-up at the house, I got slightly better signals on the HD sats, but the dish stand was on a level concrete slab.
Key point:
when you enter your zip code to get the coordinates with this kind of set-up, use the coordinates for the Phase III dish, not the Slimline, this will get you in the ballpark. Then switch dish type to the Slimline to continue set-up.
I didn't get my locals as I was out of my "locals" spotbeam at the campsite.
Key point:
