Hi all!
New here...
So I'll describe my setup and location...then describe the issue in detail so as to avoid confusion.
[Setup and Location]
San Jose, CA 37N, 122W
Unipine Orasat 36" Ovalized Dish (T to B is actually 41")
0.4dB Standard LNBF - Skewed Clockwise about 5-10 degrees,
Ponted at Galaxy 10R using a -15.75 degree compass correction.
Viewsat 2000 Platinium Set-Top Receiver
Twinhan 102G PCI DVB-S Receiver
Signal Averages 69-70 Strength
Quality Varies from 29-72 Depending Upon the Transponder
[End Setup and Location]
[Issue Description]
Twinhan which has a 25 foot longer cable run gets the following with ease:
11805H
12035V
12114V
It picks em up, determines what channels are available - I can view/listen to them.
However, the Viewsat can see the transponders - even gets an adequate quality signal for them - but the moment it tries to scan for channels - FAILED is the message. The quality bar during scanning will actually go blue at the outset.
I've tried to find a way to enter channels manually for the transponders so as to use LYNGSATs posted settings - but the Viewsat won't let me do it. Can't seem to specify the PPID as it always offers 8192 only and nothing ever gets saved.
[End of Issue Description]
So fire away!
Thanks!
New here...
[Issue Description]
11805H
12035V
12114V
So fire away!
Thanks!
