Here is a cut and paste of an email I received from Channel 22. Looks like I have to move to Boston to get the NFL in HD this year;
edit; here is Sara email if interested,
Sara Carpenter [scarpenter@fox44.net] notice it is at fox and not the ABC affiliate
Bob~
Once we convert over to broadcasting with a digital signal, we will switch to HD. WVNY, as well as the other area TV stations, are in the process of building digital facilities on Mount Mansfield. The plan is to have that completed by November 2006. HDTV will follow shortly after that.
When the area stations do switch to digital, then to HD, it will be through an on-air signal. If Adelphia chooses to broadcast the local stations in HD at that time, they can, but at their own expense.
As far as satellite providers broadcasting the local channels in HD, that will not happen until 2007.
Feel free to check back later in the year for any updates.
Sara Carpenter
Director of Programming
WVNY-ABC 22
298 Mountain View Drive
Colchester, VT 05446
p (802) 660-9333 ext. 162
f (802) 660-8673
