I'm planning to put up a fixed dish for the 125W PBS channels, and I intend to park the dish on the downwind side of my chimney then hopefully ignore it for years to come.
I want to use an old StarChoice 33 by 30 inch oval dish that currently has a Cal Amp 150284 0.75 dB single output LNB on it. The dish came with the property when I bought it and the LNB worked for my subscription channels from Anik F1 when I replaced the dish with an elliptical.
It would be nice to have dual outputs from this dish but not essential as I will have other sources available if we really want to view something from 125 on more than one receiver at the same time.
I also have a Cal Amp 150478 0.8 dB old pop can style stacked LNB that StarChoice used back in the day.
Possibles...
1) Stay with the original LNB cuz ain't broke don't fix?
2) Throw on the stacked cuz might be able to configure later to run to a second receiver?
3) Or, throw a newer GeoSat single or double on there to start cuz the other ones are old and I might want/need a little better quality signal at my more 51 degrees N latitude location?
Any thoughts and suggestions for the Pros and Cons would be appreciated.
Thanks.
Possibles...
Thanks.
