PBS Check
Diamond Jim
4,393
525
The Boilermaker State (#19)
Would someone verify that they are getting all of the PBS channels on AMC 21, FR 12180, SR 30000 V. The reason I am asking this is that Saturday night when I turned them on all I was getting was V Me and Create, the other channels were dark with strong signals. Since the Quali TV is a peculiar receiver I decided to clear all of the channels and do a rescan. When I reentered the FR it locked and scanned, but only brought in those two channels. I then went to the Traxis and did a blind scan got basically the same results, only the dark ones also scanned in. I then tried a manual entry on the Traxis, it shows a 72% signal but when it scans it says "no program found." I then checked LyngSat to verify that I had the right numbers and I noticed that they show another mux PBS at 12116, 30000, H. I entered that into the Traxis with the same results.
I hope this is not something like an "encryption test." I have some free time today, so I will keep playing around and see if I can figure this out.
Jim
I have read the same thing...they will be showing just the HD channels and affiliates can zoom the non-HD programs to fit on a SD screen.
There wont be a PBS SD feed but the other chanels (V-Me, Create etc) will still be in SD
see attached
  • HD%20Transponder%20Transition%20Plan%20%202008-06-16.pdf
  • HDTransitionSchedule.pdf
That's fine but I wish the people that build receivers would finally give us a "do it all" unit. I'm confused as to why this hasn't happened in North America yet. :confused:
Oh well, maybe I'm asking for too much.
NDF File Format Specs?
Invacom TWH-031 Universal LNB?
