Iceberg,
Got the 3500 today and my initial impressions are favorable. However, I am a little confused by the differences in the dish moving features between this and the Coolsat. I think I have it figured out now but after working about four hours and doing one system reset (and swapping the Coolsat back in to reset TS) I want to make sure.
1. On the Coolsat there is basically one "position setting" for everything. You can use USALS to get to a sat and then use 1.2 to fine tune, hit "exit" and save. On the 3500 it looks to me like you use USALS to get to a sat and then save your position. Then, if you want to fine tune with 1.2 you have to save again AND (this is what threw me off) you have to select a "user defined position" to do that starting at #27. If you use "null" it will not save anything. Is this right?
2. When you first go to "Antenna Position" and then hit "USALS" there is an option for “move” and it says in the manual “move by x degrees based on your longitude and latitude). This seems to make sense. However, as soon as you go into USAL it appears that the motor moves and you start to get signal without doing anything. So what is “move” for?
3. What does “Reference Position” on both the USALS and 1.2 screens do?
Thanks in advance and sorry for all the questions.
