Equipment:
1 x Pansat 3500S Complete System
Coax Cable 100ft Black
Motor Pansat PM 900S
Dish 36 Inch
LNBF Universal Single
From the documentation it is not clear, how the
Pansat 3500 S receiver shall be hooked up to the motor.
Do i have to use 2 cables
a) one from the GND-rectangle output to the PM 900S
motor
b) one from the Motor back to the INPUT of the 3500S receiver (doesn't work? as no plugs available? there
is still one cable that needs to go from the motor
to the lnb ...)
Or do i just connect the "INPUT" plug of the 3500S connector via an RG6 cable to the Motor and then the
motor to the Lnb with a RG6 cable? (i.e. both the
power and the signal are carried over the same RG6
cable?).
Also, what does it help to have 2 LNBS instead of
one if i use a motor? Do you get more channels with 2 different LNBs?
Dish 36 Inch
motor
to the lnb ...)
cable?).
