Outside model for 25530
johnny_knox
WV 25530
1. What outside antenna for free TV would you recommend for WV 25530, low to mid price range (lowes? RadioShack?).
2. I want to bring it down to one tv and then another from the outside cable junction box.... Should I use a splitter, can it be on the outside of the house?
3. The best location for me would be South side of house below the 2nd story? or is the best signals coming frome the north?
Thanks in-advance
Check out tvfool and enter your specific address. It will give you a good idea as to what you'll need.
From checking your zip code you may be able to get away with a set top antenna on each. You probably won't have trouble with really any antenna. Yes you can split it, outside is fine if it's protected. You will lose some signal however. You could try it first and if it doesn't work that good, try a distribution amplifier.
You may need a rotator, check the map.
Good luck
Shop on-line, neither Lowes or Radio Shack.
Cheapest Antennacraft HBU-22
Likely to last 30 years Winegard HD7694P
Aim the antenna between WSAZ and WCHS.
A more exact report may be necessary to be sure.
TV Fool
If you want several PBS stations consider a rotor.
Which way to aim this antenna
Is it possible, West Palm or Miami from Orlando
