I have the Diplexer install. The SAT and OTA (Wineguard Sensar II) signals are combined at the Roof, brought down through only one Coax, and then spilt using a diplexer behind the Voom Box. I understand that the Voom box uses the Diplexer to pass power to the antenna, which is required for amplification.
I am building an HTPC with a OTA HD tuner (MyHd 120). I need to somehow use the same signal (split?) to feed this second tuner too (as installing another antenna or running another wire is not an option for me.)
1. Can I just split the signal just before it goes to the diplexer?
2. In the above scenario, does the Voom Box need to be turned on, so that it can pass power to the antanna, each time I use the HTPC tuner?
3. What kind of splitter would I need and where to buy them?
4. Is there any other option?
