Need Help
The OTA TV antenna signal is carried on the same coax cable into the house. How can I uncouple or split the OTA antenna signal inside the house to feed a 2nd TV with only the local antenna signal. This second TV has a short wire as a antenna and weak channel scans, but with the Orby TV local antenna It would have a strong OTA local only TV in my bedroom.
Any suggestions if the on the roof splitter or similar spliter can be added prior to the Orby Box and spin and share the local signal to a second TV.
