OTA reception thru Zenith HD-SAT520
ajay malik
Hi, I just bought a refurbished Zenith HD-SAT520 receiver (without access card) for the sole purpose of watching OTA ATSC broadcasts.I've setup the channels but I'm unable to set the local time despite setting my area info like zip code etc. Wehever I want to see the channel 'guide', I'm asked to set the time first.
Clock (Auto)
Enables adjustment of the time zone and activation of daylight savings time. Normally, your
clock is set using signals transmitted by DIRECTV.
To set auto clock:
1. Press the Menu button on the Remote Control to display the on-screen menu.
2. Scroll down using “down arrow” on the remote control.
3. Select the Setup menu by pressing “select ”.
4. Scroll down to Clock using “down arrow”.
5. Move the highlight to the right with “>”.
6. Select your time zone between Eastern and Hawaii by pressing “>” continuously.
7. Scroll down to Daylight Saving and press “>” to switch daylight saving on or off.
8. If you want to reset the clock, scroll down again to “Reset” and press “select”.
The highlight will return to the previous level.
9. Press the Exit button on the remote control to return to TV viewing.
Clock (Manual)
Enables you to set the time manually in the ANT/CABLE Only Operation.
To set manual clock:
6. Use “up/down arrow” to move the highlight in the entry boxes.
7. Enter the number using the digit buttons on the remote control.
8. Press “<” to return to the previous screen or
press the Exit button on the remote control to return to TV viewing.
No Indy 500 in HD?!
Mounting The Dish
