What is your zip code? What type of building construction,1story/ brick/aluminum siding/metal duct work in attic to reflect strong signals? Seeing we can't see your location as much information as possible will help answer your question. What multipath symptoms are you getting seeing you have strong signals?
One Story plus bonus room. Hardiboard siding mostly below antenna level. zip 32608 Symptoms= 100% signal or close to it then message "signal lost" then back after a few seconds. Worse when the wind blows or rain. Using a dish 622 BTW. When the antenna is hooked direct to TV it is much worse. Duct work is fiberglass that is foil covered. house 10 years old.
here is antenna web data
WCJB-DT 20.1 ABC GAINESVILLE, FL 152° 5.7 16
* yellow
uhf WGFL-DT 28.1 CBS HIGH SPRINGS, FL 288° 7.5 28
yellow
uhf WBXG-CA 31 BOX GAINESVILLE, FL 42° 3.3 31
yellow
uhf WCJB 20 ABC GAINESVILLE, FL 152° 5.7 20
* yellow
uhf WUFT-DT 36.1 PBS GAINESVILLE, FL 31° 8.0 36
yellow
vhf WUFT 5 PBS GAINESVILLE, FL 31° 8.0 5
* yellow
uhf WOGX-DT 51.1 FOX OCALA, FL 161° 18.6 31
yellow
uhf WOGX 51 FOX OCALA, FL 161° 18.6 51
Not listed is new channel 9 NBC same location as WGFL comes in at 70% or so very stable
