Or both. The OTA module allows DVRing. I connect to both, just in case.
For an indoor antenna, I would think an A/B switch would be better than using a splitter. There are a couple of channels that I can barely receive a consistent signal on...a splitter would reduce that signal strength even further.I do both too but use an A/B switch on one of my Hoppers. You never know.
A splitter/amplifier would take care of signal loss, and provide simultaneous signal to both.For an indoor antenna, I would think an A/B switch would be better than using a splitter. There are a couple of channels that I can barely receive a consistent signal on...a splitter would reduce that signal strength even further.
My antenna is in the attic. Got it amplified and split 3 ways to three Hoppers. TV stations are approximately 25 miles away. Signal strength is 100% on most channels. I think it is awesome with today's digital technology. I remember back in the 50s watching the TV as my dad on the roof was adjusting the antenna for a good picture. This was in a big city with TV stations close by. Even a good picture back then is nothing like todays quality.
Correct, a good 2 way splitter will attenuate your signal by 3.5 dB which is slightly more than 50%.For an indoor antenna, I would think an A/B switch would be better than using a splitter. There are a couple of channels that I can barely receive a consistent signal on...a splitter would reduce that signal strength even further.
