I just installed a Channel Master Crossfire 3020 HDTV antenna (w/Channel Master 0065 DSB pre-amp) connected to an LG LST3510A OTA/QAM tuner and the picture is fantastic. I ran the antenna signal through the existing DirectTV SAT1 line from the roof with a diplexor and it worked great (I learned the hard way that a DC "block" filter is required between the tuner and the 12v SAT1 DC signal). The quality of a digital OTA image is clearly superior to my DirectTV. It appears that the key to this set up, though, is the ability to rotate/adjust the antenna remotely so that all local OTA channels can be tuned in easily. I used a Channel Master 9521A with handheld remote.
