OTA HD Tuner Recommendations Please
navagator
SatelliteGuys Guru
142
26
I’m going to be in the market for an OTA HD Tuner in the near future and would like your recommendations.
It must have a strong tuner, pass 480i through components, provide at least 3 hours of EPG data, and have a good picture.
I currently have a Zenith DTT-900 converter box which does an excellent job pulling in long distance stations. The main station(s) I watch are WHO/AntennaTV in Des Moines, which is approximately 83 miles away. The signal meter on my Zenith bounces from about 65 to 75 percent for these stations and I rarely ever experience any dropouts unless we are experienceing bad weather.
I want an HD box that will perform at the same or close to the same level as my Zenith convert box does for long distance signal reception.
My original idea was to try to find a good used LG LST-3100A/4200A box. They seem to be a very well made box and as far as I can tell meet all my requirements, and I know my Zenith converter box is made by LG so I thought the 3100/4200 would perform similarily. However, after some research I found that the 3100/4200 uses the older 4th generation chipset versus the 6th generation chipset that my Zenith box uses. If I understand correctly the older chipsets don’t do as good of a job pulling in long distance signals, so I don’t know if the 3100/4200 will work for me. I need to be able to receive WHO.
I’m not sure what chipset the Centronics ZAT 502 HD/RTC DTA100 HD/Digiwave DTV5000HD units use, so I'm unsure one of these boxes would perform as well as my Zenith for long distance reception.
The Channelmaster CM7001 seems to be a nice box but if I understand correctly it only shows the program data for the program that is currently showing, basically no EPG.
I also ran across the Firebird DCT210 which I really can’t find a lot of information about.
The Winegard RC-1010 seems to be a decent box, I’m not quite sure what chipset it uses. I’ve read where it could be a 4th or 5th or even a 6th generation.
I welcome any suggestions regarding any of these boxes or perhaps another brand of box that might work for me.
Thanks.
I'll have to check the model number on my LG LST at home. I took it out of service and might be willing to sell it. I'll get back with you tonight.
I use TiVo for OTA HD. It works really well. If you can find a TiVo series 3 on ebay with lifetime service at a good price, it would be a good option. Then you will also have a DVR for OTA.
Mine is an LG LST-4200A. I have it connected to a TV we don't use anymore.
Could you tell me what the approximate distance of the fartherest station you can receive a stable signal from on your 4200 is? That might give me a rough idea of what the long distance reception capability is for the 4200.
As I said in my orignal post I receive a stable signal for WHO on a daily basis (aside from when we have bad weather) with my converter box and older Radio Shack VU-160 antenna with amplifier, about 35 foot in the air.
antenna element lengths?
Advice for my Antenna Set-Up
