I have just installed a Channel Master antenna with channel master 0065DSB pre-amp which is connected to, and draws power from, the direct tv dish through a channel master 4032IFD diplexer to combine SAT2/UHF. I use a DirectTV DVR so there are two SAT lines (1,2) coming in to my Direct TV DVR and a third line that goes to another room.
At the Direct TV DVR, I have another diplexer (same model) to split the incoming SAT1 and UHF/SAT2 signal into SAT1, SAT2 and UHF. SAT1 and SAT2 go to the DVR, while UHF goes to the LG 3510 HDTV tuner.
With the UHF line dis-connected from the LG tuner, I have a clean signal from both SAT1 and SAT2. When the UHF line is connected, my SAT2 line drops out completely. HELP!
Any guidance on this would be truly appreciated!
