OT: Putting higher power IR LED in remote?
Mark_AR
1,448
North Arkansas
I use a compaq iPAQ 3955 as a whole house home theater Infra-red remote control.
It doesn't have a whole lot of range(Like about 6-8 feet typical) but my 522 has a sensitive eye and it will control it to 12 feet.
I'd like to put a higher power (brighter) LED into the iPAQ for better distance controlling but there are so many to choose from.
Does anyone know about electronics enough to tell me what I could use? There are so many with different wavelengths (720-1500 nanometers), power outputs, etc.
I've been google-ing and found this place:
http://www.roithner-laser.com/LED_diverse.htm
It tells alot about IR LED's but I still need to figure out which type will work.
Radio-Shaft has one for $1.79 but it is only 7.3 milliwatts.
I still have to find a 1-2 mm allen screwdriver and a torx bit to get the iPAQ apart and see how I could get a different LED in the case.
Alternatively there is something called 'Total Remote' by Griffin Technology. It plugs into the earphone/audio out jack and retails for $24.95. It isn't 100% compatible with devices and they make no guararntee.
I'd rather go with a higher power IR LED. Any insight?
Thanks!
MPEG 4 News
Read About My Nightmare As A Dish Network Customer!
