Yes I have done the selection from the menu receiver Bev 6000 is hooked up to an Onkyo A/V receiver.
Sometimes if I tap the casing around the optical out on the receiver it blinks on and off.
Also check the RF (coax) output to verify you have recorded sound. Then work up to 3-wire composite, which should be the same. Then to 5-wire component. Finally to HDMI with no HDMI-DVI adapter(s). Then you should know where the problem begins.
-Ken
Thanks, I am noticing with Line the channels that used to boom in are now around the same volume as the rest. I'm using a toslink hook up because my Yamaha upconverts component, not HDMI, so my SD looks better, no difference except for 4 cables instead of 1.
