Has anyone had a good experience with the Fortec Star 90cm Dish Antenna? I ordered mine from Sadoun and it seems really cheaply made. The reflector bends very easy and the LNB arm does not seem sturdy because of the reflector mount doesn't seem very strong either. Everything just seems structurally weak. Seems hard to lock onto a signal, expecially with AMC 21. When I got it from Sadoun it seemed like it was previously assembled and was missing some nuts and bolts. The two screws that hold the LNB arm to the reflector mount stripped and never held it on properly. I had to buy the nuts and bolts just to secure it tightly. The LNB holder doesn't seem to fit the way it should either.
The Fortec Star prime focus antennas are not built rock solid either, but everything is held securly and very strong. Much more rigid.
Is there something I can do to make this 92cm dish antenna more secure or should I just go ahead and buy the Geosat Pro 90cm offset dish from satelliteav? I do like Sadoun though, in fact I like them both, as well as Fortec Star.
Thanks.
Jonathan
Thanks.
Jonathan
