I'm a new customer and the installation is not yet complete because the 522 does not see the odd tp on 105. Unfortunately, my locals (NW Ark) are on tp 23. I'm a newbie and the tech who is doing the install is baffled. Not the best formula for success.
The installation tech swapped every component of the installation: 522, switch, dish, cables, ground. When he checked the signal by connecting a 311, he got good reception i.e. even and odd tps for 110, 119 and 105!
DISH gave the tech some suggestions: e.g. "resetting the matrix" by running a check switch with 105 disconnected at port 2 of the switch (DP34) and then rerunning the check switch with port 2 reconnected. He was given conflicting direction about whether the first check switch should be done with the dish set to 500 or super. He tried it both ways.
Any suggestions?
John
Any suggestions?
