Only have signle on 101° transponder 28,30,32
matthewj
4
SW Virginia
After much tinkering with my new slimline 5-LNB dish I am only able to receive 60% of a signal at 101° on transponder s 28, 30, 32. Any ideas what might be causing this? After looking through the forums it seems like this is the spot single which indicates to me that it would be the most difficult to find. When I use an analog single meter I get a feedback but still can’t get anything on my new receiver..
sounds like the 101 LNB is picking up 110 as they only use 3 TP's (28,30,32)....the dish needs to be moved east 9 degrees
Yup. The Slimline points at 101. Like Iceberg said, you are likely pointing at 110.
Switched from Dish - first impressions
H23 receiver opinion
