On-line Channel Guide?
blockisle9
217
Hi gang,
Is there a web-site that I can go on line and view a TV guide for dish 120 with my locals that I can customize? Ive tried TV guide, they don't have a setting for dish 120 just "all available" and when I spent an hour customizing it, they allways end up getting reset and I have to re-do it.
Thank you
You might try TitanTV.Com. Though it shows ALL satellite tv shows by time and date, it is fully customizable and your selections may be saved as FAVORITES.
It is tedious, but after you have saved your favorites they are always available and you may check the schedule for today, or any day/time in the next couple weeks or so. They are printable.
Once you have joined (no cost) and provided your zip code, it will also provide you schedules for your local SD and Digital stations.
Thank you,
I finished!
Could not add a few channels not listed:
Documentary Channel (197)
Reel Z (299)
Toon Disney(847)
IMF(IMF)
I'll try and find the stations call letters and try them, the names did not work.
Thanks again!!
While this isn't necessarily a 'tv guide' site, some of you might like to visit thefutoncritic.com.
The page I really like is the "what's new tonight?". It lists all the first time showings of programs each night. Helps to decypher if you're going to be recording a new show or a repeat. If it's not listed as new, then there's a 99% chance it's a repeat.
blockisle9 said:
Thank you,
I finished!
Reel Z (299)
Toon Disney(847)
IMF(IMF)
Thanks again!!
You are most welcome.
Those channels will likely be added at some later date.
blockisle9 said:
Thank you,
I finished!
Reel Z (299)
Toon Disney(847)
IMF(IMF)
Thanks again!!
I have Documentary (197), ToonDisney (as 174), and IMF (157) listed in my TitanTV.
I could not get Reelz, either. But, the other 3 are available. (IMF has no program info though)
Intermittent audio dropouts on ESPNHD.
Can I use HDMI and Component Simultaneously?
