Old Primestar dish success
RocketRay
40
SoCal
I got my old Primestar dish pointing at IAS5@97deg and it works pretty well. After skewing the original LNB and setting the elevation right for my location, I put the dish on the perfectly leveled mounting pole and only had to get it pointed precisely after that. My wife reported the level while I turned the dish, and we got it to about 75% quality. If we get rain fade (no rain here in SoCal for another week at least) maybe I'll need finer adjustments to fix that.
Problems:
Tried manually setting the satellite, TP and channel with GTools but had 0% signal quality. A downloaded channel list with the unnecessary satellites removed fixed the problem.
The LNB on my old dish has two outputs, H & V. I've hooked up both to the disecq switch, but quality on the H output is only around 45%. Since there are no channels we're interested in on that polarity, I'm not going to bother getting that to work.
So, color me tickled pink!
A DiSeqC switch is not the correct switch for merging polarities. Are you using a Fortec or Pansat. If Pansat, use the skew controls to select the polarity with a 0/12 VDC switch.
Pansat 2500A
I'm using a DiSeqC switch cause that's what came free with my receiver. But since H doesn't have many channels, I'm going to declare mission success anyway. :)
Royal Angel IA-7
Using SG2100 with diseqc 1.2
