So I had Directv scheduled today for a dish mover, the installer was slated to show up between 8am and 12pm. CSR said he should be around 8am. Guy didnt show up untill 1150am. Showed him the job (I allready had a pole mount in and pointed. All he had to do was run the wire to the ground block, attache his wire to the existing wire that goes through the wall into the garage. From the garage he had to cut the wire put an end on it and hook it up to the SWM in port.
I showed him how att wired and told him to follow sute and told him that the wire went into the crawl and all he had to do was push the wire up where att's is and put on a dual wallplate. Also explained to him that ATT predrilled the holes using a 1 in pattle bit so he should have no problems pushing the wire up and to the wall plate wich is 1 foot up from where the hole under the crawl is. From there remove the existing wall plate and put in a dual. Attache uverse to the wall plate on both sides and crimp and attach his to the other port on the wall plate.
Also told him all i needed was direct berrial wire layed so I can berry it later from the pole mount to the ground block. This job is CAKE! Guy goes to his truck and comes back with coustomer service on the phone trying to say he has to do a full blown wall fish and is trying to charge me. Sorry guy, but thats not the case. I even mentioned to coustomer service that it seems like the guy is trying to get out of the job as its really simple, if I had the wire I would have done it myself. Come on now the dish is allready on the pole, pointed and holes and wall plates are allready in. Just have to bring the wire up.
The guy started steaming and started saying that I was saying that i thought he was trying to nickle and dime me, wich i never said. He then said im not going to work this job and started cussing up a storm. Called up directv and DIRECTSAT USA. They are sending someone out tommorow night. WOW this guy was out there, for such a simple job. All of the holes were pre drilled, and good to go for him. CRAZY! The amount of time the guy spent cussing ( he was like f this and fbomb that.) on his phone and smoking cigretts in his van he could of had the job done by the time he was finished. I really hope this guy gets fired as he really and I mean really is not the shining image of what a directv installer should be. I have never seen anyone so rude. Wow is all I can say!
