It also seems the "Pause bug" from L3.65 is gone. I tested it on live tv, and it worked normally.
rocky - Can you please give me a summary description of the "Pause bug"? I want to see if this is the same thing I'm experiencing....Thanks
Neither dfergie or I put our names on the beta list, but it spooled nonetheless.
Sounds like they are taking the Microsoft approach. Just spooling new software, even if it is buggy. The customer be damned.
BUT So far so good; no "blue screens of death" (so to speak)![]()
I don't think it was ever said that only the ones that submitted their names would receive L4.01. I believe these receivers were in addition to those already planned. None of these "testers" received the load unless they were going to receive anyway.
At least that's what I think, until I change my mind.
I understand. The software report did say that it was a phased spool. So, some of us got it, and some did not.
Its kind of curious how they wait to call for "beta" testers until they are releasing it to large numbers of customers. But I guess that gets them some feedback (which they could always get by just reading these forums!)
The "pause bug" is what happened when you hit pause on live tv, and then unpaused, and it would JUMP to live tv, instead of actually pausing.
It usually only happened if the pause was less than 30 seconds in duration; and it only occured with live tv programs, and not with DVR'd stuff. I can try to hunt down the original threads on it from last fall if you'd like.
But from my quick tests today, it seems to be gone - at least for me.
What are you experiencing?
Had to run home at lunch (wife had an emergency, could not switch from DVD to SAT), and found I was a lucky lottery draw and got L4.01 last night. I will be playing tonight and will post anything I find.
to SatelliteGuys.US! You'll love hanging out here, and you'll learn a lot too!Had to run home at lunch (wife had an emergency, could not switch from DVD to SAT), and found I was a lucky lottery draw and got L4.01 last night. I will be playing tonight and will post anything I find.
I am happy to report that my L4.01 problem is FIXED and was not a problem with L4.01 but instead a problem with my DPP44 switch which is cascaded off my DP34 switch!
I was able to reset the switch by unplugging everything from it for a few minutes then plugging it all back in.
AGAIN THIS WAS NOT A L4.01 ISSUE!![]()
Still doesn't mean that 4.01 didn't cause your 44 to lockup.. After all it quit working after the update.. But maybe it was just coincidence..
