Off air Antenna and TV2
TMaud
21
What is the best way to be able to view Off Air Broadcasts on TV2 with an off air antenna? TV1 has the TV Antenna/Cable input but TV2 doesn't.
Use a combiner to combine the TV2 output with the antenna. Then you can change channels on your other TV to watch local programming and go to the modulated channel to watch satellite programming. Just make sure you use a combiner that will prevent back feeding the TV2 output to your antenna.
Disabling 522 DVR on 2nd TV
811 program guide
