Been with DTV since '94. I've had many issues over the years and all have been resolved with one visit. Current issue is the worst kind. Intermittent with no way to cause the failure by repeating any steps. Not sure where to turn but this seems to be the place. Haven't posted this elsewhere. I want to help the tech solve this.
Problem: Continued, repeated 771 errors for no apparent reason before and after tech repairs applied.
3 boxes are:
HR24/100
HR24/200
HR22/?
Started 8/31. Hard 771 outage until 9/6.
Tech arrived 9/6.
Replaced LNBs
Replaced spliter
Re-terminated all coax cables and replaced connectors
Worked okay until 9/14 when 771s returned. Satellite reading were all in the 90s yet 771 persisted then went away without any action on my part. System working okay.
On 9/15 system worked okay (sat readings in 90s) then 771s reappeared. Tech arrived same day and replaced all coax connectors in wall plates. Check main cable run from satellite through attic to main connector box in basement where splitter is located. Found no connecters or breaks in coax. The coax cable run from the satellite to the basement is one continous cable.
9/16 (today) system worked fine. I decided to watch a pre-recorded show. When recorded show was over at 10:15 flipped to live TV. 771s are back. Sat numbers all zeroes. Pressed red button. Got 771 when rebuilding guide. Reset didn't complete. At 10:39 live TV returned. Sat readings are all in 90s.
My conclusion: Something the tech did on the 9/6 visit "fixed" the problem in the sense the hard outage "improved" to intermittent after one week of perfect reception.
I am confused. What could cause this type of issue? Can anyone help me out here. This is unacceptable. Tech is great and customer oriented yet I'm sure not that experienced.
This is not weather related. There have been no storms or heavy rain since the issue began.
Thanks for any suggestions.
Dave-
3 boxes are:
HR24/100
HR24/200
HR22/?
Tech arrived 9/6.
Replaced LNBs
Replaced spliter
Dave-
