I saw Sharpee's thread about a Traxis with C-band, but didn't want to hi-jack his thread, so I started this one.
I bought a used Traxis 3500 from Stogie last week and hooked it up as a slave to my 4DTV, partly because I wanted to get used to using it, and partly because I wanted to confirm how well I have that dish set up.
Got everything hooked up and started setting up the Traxis. It is a little different than what I am used to, but I have now learned my way around the setup screens pretty well.
The Traxis likes diseqc 1.0 if you only have 4 ports on the diseqc switch. It doesn't like 1.1 unless you have uncommitted and committed switches.
It also requires that you have LNB on even if the LNBs are being powered by another receiver. With LNB off, the diseqc functions don't work, and you get C-Band signals coming through the Ku side.
I am having another issue with horizontals being scanned in as verticals, and verticals being scanned in as horizontals. A lot of duplicates.
I think that has more to do with the position of the feed-horn. I have mine set at the 10:30 - 4:30 position maybe even leaning towards the 9:00 - 3:00 side which works great with the 4DTV since it has control of the polarity and skew and you can adjust it any way it needs to be. I think, and this is just a thought, that the Traxis looks at it like it is extra skew and reacts accordingly.
I think I will probably have to make the feed-horn a little more towards the 12:00 - 6:00 position to satisfy any DVB receiver that doesn't control polarity. More like an 11:30 - 5:30 position. That would probably eliminate all duplicates.
The problem could be eliminated perhaps if the Traxis had a method to scan one polarity at a time which it doesn't, at least I couldn't find it. To me that is a serious drawback in it's firmware and I will be addressing that with Tim at DMSI.
I got the Traxis for one major reason. It has a pin-point accurate and rock solid meter along with fast and accurate blind scanning. I am getting tired of unhooking my Pansats to go up to the roof to fine tune dishes. I have plenty of old analog receivers that I can take up there to move the dish with the Traxis slaved to it for that job. I might get a spare VBox for that job too.
If all goes as planned, this unit will be slaved to the spun aluminum dish when finished and the pc tuner slaved to it for blind scanning and recording. It will be very easy to unhook and hook back up. Hopefully in another 6 months I will have the Fortec Passion, or the Pansat 9200 for that job, and the Traxis will only be used to fine tune dishes.
On the plus side, the dish seems to be tuned pretty well. It actually works better with Ku than with C-Band. I also was able to input a strong C-Band transponder for IS-9 (PAS9) at 58W and scanned in the channels there. I was surprised to see some actual stuff for the 4DTV there too.
I am not going to make any changes to the dish until I see whether I get the solid Birdview that I am "tracking in the hunt". If I get the solid BV, the perfed BV will be sitting in this spot.
If you think I am incorrect about the duplicate channel issue, or have a different thought, please let me know?
Fred
Fred
