OK, I have a Panasonic TH50PX80U 50" Plasma TV. A cursory look at the available documentation points to 720p as it's resolution limit. However, after spending an hour last night messing with the TV's various settings and my HR22's various settings it seems as if my TV will display 1080p. Here's the thing, when I check the box for 1080i I can see the "if you can see this message, your TV supports this resolution" message. Then, when I select 1080p, I see a "blip" on the screen and the picture-in-picture shows "Testing 1080p" with both the 720p and 1080i indicator lights lit up on the HR22's front panel. I quickly checked the resolution on the TV with the "info" button on the TV's original remote and I'll be damned if it didn't show 1080p in the resolution field ! At that point I see the "if you can see this message, your TV supports this resolution" message and am asked to press "info" to confirm then I see another message about "1080p is available!" but not being selectable from the "format" button on the remote.
So, how is all this possible ? The manual shipped with the TV refer's to 1080p as an available resolution. Here is an online copy of the manual that came in the box .... pg's 17, 40, 42 & all refer to 1080p.
h**p://static.tigerdirect.com/pdf/Panasonic-TH50PX80U-Plasma-HDTV-Manual.pdf
Here are a couple of online references that support my 720p limitation idea ...
h**p://www.panasonic.ca/english/audiovideo/plasma/specs80.asp
h**p://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=3811029&sku=P333-5044&srkey=TH50PX80U
I'm sure I'm missing something but I'd bet that one of you guys will clear it up for me.
Regards,
UB.
Regards,
UB.
