Not Vooming yet
.....Vooming now though.
Well, I'm not Vooming yet.
The installer has left. I am not able to get a good signal at the stb. Installer says that the signal is 93 at the Sat, but only 30 at the stb. He is blaming my run of cable. He said there were too many connections between the Sat and the stb. I ran brand new RG6 quad shield cable from my attic to the wall jack in each room where the stbs would be located, there are no other breaks or splitters. When the Dish was put in, the installer needed to run a cable into the attic then use an inline F-connector to connect to my cable and there is another inline connector at the wall jack. Could two F-couplers cause that much of a signal degredation? I don't think the total run of cable is more than about 75-80'
I'm going to do some trouble shooting when I get home. Wife was there during the install.
The installer has left. I am not able to get a good signal at the stb. Installer says that the signal is 93 at the Sat, but only 30 at the stb. He is blaming my run of cable. He said there were too many connections between the Sat and the stb. I ran brand new RG6 quad shield cable from my attic to the wall jack in each room where the stbs would be located, there are no other breaks or splitters. When the Dish was put in, the installer needed to run a cable into the attic then use an inline F-connector to connect to my cable and there is another inline connector at the wall jack. Could two F-couplers cause that much of a signal degredation? I don't think the total run of cable is more than about 75-80'I'm going to do some trouble shooting when I get home. Wife was there during the install.
