I merged your two threads together
Joe...do me a favour and READ the reponses people put in your threads. That will help you along the way. You keep posting and not reading the answers people give. I have posted now in THREE different threads the same answers to the same questions you ask. But since its late and I can't sleep I guess I can regurgitate the same info again
when the tp is inactive will the tp scan not bring in the channel or will it bring it in even if the feed isnt on at the time?
NO, nada, nyet, nope, no sir-re-bob...no signal no channel
it looks like as long as the tp is there it would scan the channels regardless of if there is a feed on or not.
again, no. Since it doesn't know the symbol rate it can't scan it in.
i like analog because i just go to a sat and manually scan, it takes me maybe five minutes to go through the sats on analog.
thats because the frequencies are the same regardless of satellite. Only difference is what chanels are V and what channels are H. So Channel 4 on G3, G4, G7, AMC3, AMC6, AMC7, etc are the same...only diff is polarity
sometimes a blind scan on just one sat takes me five minutes!
heh, try a satellite like G3 when the signal is nuts on. It will take longer than that.
i guess maybe i am scanning at the wrong times on the dvb. i have noticed when i am off on friday tons of analog feeds are on in the morning so i will scan for feeds in the morning with dvb.
There are channels up on C-Band Digital 24/7. Try to lock on those. Again, analog has slack and you can be off a smidge and still get a good picture. Digital has to be Nuts on or no signal (or weak) and in some cases the dish has to be nudged for 2 different channels on the same satellite
i was wondering if anyone knows what might be wrong with my setup. i am using a 8 ft unimesh c band system. i am getting 75 pct quality on my sats, but i am not getting all the tps on the sats. like t6, i am getting perfect reception on the analog and 80 pct on about 5 tps, but then there are 4 or 5 at only 40 or 50 pct and the rest nothing at all!
T6 is a bugger. I have a thread on that here with my 6 footer
arent all the tps the same horizontal and vertical as they would be on analog.
nope. They can be either or.
on my analog my receptions are usually 180 for vert and 120 for horizontal. are the digital the same pretty much?
I have no idea what you are saying there...are you talking about skew?
i mean obviously my dish is pretty well aligned or i couldnt get 80 pct quality on the sats.
not necessarily. Some satellites have very strong transponders. I can get World Harvest on G4 at a 75-90+ and unless I'm nuts on the nets on G4 do not come in. If I go far enough east I can get BYU TV & KCSG on IA5 at the same time but not much else on G4 besides the nets (low quality) and WHT.
The best thing to do is put in a KNOWN active digital transponder and try to see if the dish can pick it up. Try it on a couple satellites. If it doesn't work, then the dish isn't aimed 100% properly.
I can get analog no issues on the 6 footer but unless its peaked just right digital will not come in.
