HMMM... geostationary orbit over the north pole. They could service most of the northern hemisphere.
I think you must be talking about the Molniya orbit. Highly elliptical 12hr period with a long apogee dwell. This allows the satellite to spend most of it's time at high latitudes. This permits an antenna also at high latitudes to point at high elevation angles minimizing obstructions and weather problems, but at the expense of tracking the satellite through the sky.I know there are a few northern sats on c band that the russians put up there way before the days of the clark belt.
so is that...Question: are you familiar with the term "due dilligence"?..Or how about becoming an "educated consumer"?..Well........if you knew absolutely nothing about satellite systems and how they work then you might be likely to ask something like that.
Not possible. Being in "orbit" requires movement around something. The geosynchronous satellites are above the equator, moving at a speed which matches the Earth's rotation, that's why they "appear" to be in a fixed location relative to the ground. Above the North Pole there would be no relative movement other than straight down!HMMM... geostationary orbit over the north pole. They could service most of the northern hemisphere.
I arrive at their home and they are clueless. Some do not know what porgramming they ordered, the number tv's to be connected. One thing they do have on common is they all want their hand held.
my favorite one when you show up and there is no line of sight and people tell "Well cant you just move the satellites?" yes ill get right on it and i will go back to the other 14 million customers to re point there dishes as well.
