No signal on TP 22 Sat 110
Dune
SatelliteGuys Guru
145
Kailua Kona, HI
Is anyone else having a problem getting updated guide info?
I get absolutely no signal on TP22/Sat 110 and my guide will not update.
All of my channels come in and a check switch confirms both 110 and 119.
I rebooted the receiver but nothing seems to work.
Do you think this is a receiver problem or is Dishnetwork having a problem.
Thanks, Dune
Run a check switch and let it down load the guide and then check back and see if you get anything on transponder 22. I get a 85 signal strength on that transponder. Also check and see if you can get other transponders on 119 as well. IF you can't get that one on 22 you might need to see if your lnb is going out.
Possible Return to Dish
Wireless Phone Jacks
