Hi,
I installed a new 3LNB for HD, put 4 cables into a 5X8 switch.
On my Hughes HTL-HD i only get Sat A at 95%, and sat B and C are at 0 with no signal.
All the other boxes in the house (4 other ones) get 100% for SAT A (they do not use the other LNBs)
Why Am I not getting B or C on the HD box? I have RG6 running from the dish to the switch, and then the coax from the switch out to the TV. It is split on the other end with a channel master splitter seperating the OT antenna with the sat in.
What should I be doing? Why does SAT A look so good and B and C are at 0?
Should their be a special order to the in ports on the switch, do i need to flip around the two new cables on the switch?
