No ESPN
tommyd12345
22
greenbrier,ar
Maybe sat is getting blocked, but most HD channels are ok except for Espn(hd and sd),espnnews,etc. Espn2 is ok. Any idea's? Did a soft boot and check switch.
All Sat signals were in the 30-35 range on 110,119,and 129. Have 2 Hoppers and 2 Joeys and they are showing same problem. Thanks
I believe that ESPN is on sat 119 transponder 7.Check the strength on that.
I guess I will call Dish and set up an appointment to check the dish because I'm getting low numbers on all 3 sat. This best signal I got was 39 on 110 sat.
Thanks for the info.
go move it yourself - shouldn't be too hard to figure out which way to go its either right/left or up/down. But keep in mind that low signal levels may not be dish alignment issues it may be the receiver starting to tank.
Hook up a slingbox to a hopper (2000)?
Recoimmended viewing right now: Free TVJ-Weekend Japanology
