Need some advice.
I just moved so I am in the process of setting up my BEV dish. I bought a new dish/lnb (dish network 500 with the new lnb with the port 1, port 2 and lnb input configuration). I got the dish set up and tuned for the 91 bird and get great signals on all transponders. I couldn't get any signal on the 82 bird for a few hours. After running the check switch routine several times and waiting a while, the 82 transponders started showing up one at a time. I get most transponders in the 45-60% range. Is this normal for the 82 transponders to show up slowly like this as opposed to the 91 transponders which showed up immediately, or is my lnb defective. I've never used this type of lnb before.
Also, I can't get any signal on two 82 transponders (7 and 11) not matter where I move the dish and no matter how I fine tune it. Any ideas what I can try. I am thinking about getting an older style lnb with the SW21 and see if that helps.
Any help would be appreciated.
