The Nexus-S is a PCI card designed for FTA reception.
Originally developed by Technisat and sold as the SkyStar1, Hauppauge took on this card in Europe where FTA has exploded in recent years.
Both are basically the same card, have the same features and use exactly the same drivers.
The main feature that sets the Nexus apart from the competition is the inclusion of an onboard hardware MPEG-2 decoder with TV out so you can watch FTA on your monitor or your television set - both at the same time or independently.
The card includes an IR remote, remote sensor, Audio/Video cables and driver/application CD.
The connector toward the back of the card is for an optional CAM interface.
Software compatibility is probably the highest of all cards with numerous applications being developed for it all the time.
The card can also run in software mode to receive HDTV or 4:2:2 feeds.
In software mode the burden of MPEG decoding is taken from the onboard decoder and routed through software so is entirely CPU dependent.
It also handles Diseqc switching, USALS motor control and 22KHz switching (Although I haven't tried the 22KHz switch)
As with the SkyStar2 card the capabilities of the receiver are only as good as the software used, I still use ProgDVB as it is updated on a weekly basis by the author and new plugins are being written for it all the time.
Some of the available plugins:
3 different Diseqc/USALS for motor control.
Stream router to enable more than 1 PC to take control of the card.
A scheduler to record or watch The Simpsons every night (for Pete)
The plugin I use for my SG2100 is DiseqcU:
For flexibility and ease of use, this plugin is amazing. It features an editor to program your Diseqc 1.2 positioners memory as well as USALS to make your installation a lot easier.
Those with a slower machine will definitely appreciate the onboard MPEG-2 decoder as it barely takes any CPU power at all - most of the work is offloaded to the Nexus.
ProgDVB features a timeline in which you can pause, rewind and record live TV - This buffer can be as large as your harddrive and comes in handy for catching those awkward feed moments.
There are several applications written specifically for this card to turn an old PC into a set top box, most notably VDR which is a Linux based installation with PVR capabilities, DVD playback and a lot more.
If you're a Windows user you have at least 5 choices of great applications to turn your PC into a PVR with this card, most can run the card to a TV set without interrupting PC use leaving the PC free to surf the web, etc.
Channel changes are fast and take roughly 1 second depending on the bandwidth of the channel being switched to.
Overall this card is definitely the cream of the crop, I've never had any problems using the Nexus-S and it performs flawlessly.
