Newbie Question on LNB
jodaesca
7
I have this lnb
Horizon c band hemt LNB with noise 25 K
Ii it useful for DVB reception?
Will likely work fine. If it has a LO (local oscillator) frequency of 5.150GHz and stability of 1 MHz or better it would be a standard LNB for FTA C-band. Maybe take a picture of the data plate on the LNB and attach it. It should be like the following:
Input Freq. Range: 3.7 - 4.2 GHz
Output Freq. Range: 950 - 1450 MHz
L.O. Frequency: 5.15 GHz
L.O. Stability @ -40 to +60 °C: ±500 kHZ
Noise Temperature: 25 °K
Gain: 57 dB
Gain Flatness: ±0.5 dB per 40 MHz
1 dB Gain Compression Minimum: 0 dBm
Image Rejection, Min.: 40 dB
Good luck..
-C.
Thanks,
the data plate states:
Gain: 65 dB (typ)
I live out south, I can not post frecuently
Ill try and later let you know
how do i get started
Multiple T.V.'s
